Displays VRRP information for a particular VLAN.
| vlan_name | Specifies the VRRP VLAN. |
| vlan_list | Specifies the VRRP VLAN list of IDs. |
| stats | Specifies statistics for a particular VLAN. |
N/A.
Depending on the software version running on your switch or your switch model, additional or different VRRP information might be displayed.
If you specify the command without the stats keyword, the following VRRP information appears:
If you specify the stats keyword, you see counter and statistics information for the specified VRRP VLAN.
The following example displays configuration information for the specified VRRP VLAN:
# show vrrp vlan v1 VLAN: v1 VRID: 1 VRRP: Disabled State: INIT Virtual Router: VR-Default Priority: 100(backup) Advertisement Interval: 1 sec Version: v2 Preempt: Yes Preempt Delay: 0 sec Authentication: simple-password key: none Virtual IP Addresses: Accept mode: Off Host-Mobility: Off Host-Mobility Exclude-Ports: Tracking mode: ALL Tracked Pings: - Tracked IP Routes: - Tracked VLANs: - Fabric Routing: Off * indicates a tracking condition has failed
The following example displays statistics for VLAN vrrp-1:
#show vrrp vlan v1 stats VLAN v1, VR ID 1 VRID Errors : 0 Authentication Type Mismatch : 0 Version Errors : 0 Invalid Authentication Type : 0 Checksum Errors : 0 Authentication Failures : 0 TTL Errors : 0 Advertisement Interval Errors : 0 Packet Length Errors : 0 Address List Errors : 0 Advertisements GotV3 DropV2 : 0 Advertisements Accepted : 0 Priority Zero Packets Received : 0 Become Master : 0 Priority Zero Packets Sent : 0
The vlan_list variable was added in ExtremeXOS 16.1.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
